Epoxy primer in a spray can
Ive use an Etching Primer on bare metal out of a can ,works great for me,I buy it from a body supply company,i dont buy it from our local car store
Sorry guys i messed the link up.
I,ve used it for mine, but when I get to the final stages, I will use the primer the bodyshops use and put a couple coats on then wetsand b4 I put the sealer coat on.
YES I've used it, and it did a beautiful job. You have to plan ahead though, because just like any two part paint, once you mix it, it has to be used in a few hours.
-=Photon440=-
If you mean the Spray Max 2K Epoxy Rust Cure Primer - 3680032 yes, I have used it. Works great. It's under my R4 red in the engine compartment on the 69 RR.
