Equus 8200 in a 73 Satellite
In your pic (post #17); the OEM sensor on the bottom is designed to be installed directly into the water with (pipe) tapped opening. The sensor shown on top is designed to be installed into an adaptor (whether open or closed style) which screws into a (pipe) tapped opening beforehand. If the adaptor is a closed style, then the void should have a high temp grease like never-seize to displace the air between sensor and well (adapter).
How about a pic of your available possibilities in the manifold especially?
Thanks for the ideas!
Of course I forgot to make pics while working on it today.
I'll Post pics tomorrow when I'm at the garage again.
Here is what I used for that gauge. Go to jegs, type in mopar thermastat housing spacer and your answer will appear
