340runner
- 10:20 PM
- Sep 2, 2024
- Naperville, Illinois
Okay, sorry if this topic has been posted before, but with the new season coming up for me and is my first true season racing, I'd like to know what I'm getting into performance wise and ET times.
I have a 71 roadrunner with a 340 that's lightly modded but by the previous owner, so I'm unsure of what pistons so I don't know compression ratio but it's .030 over, speedmaster heads, a Comp Cams 243/257 thumpr, and a holley double pumper 750cfm and a eddy Torker 2 340.
The trans is a rebuilt 23 spline close ratio trans, 1 to 1 final drive on a Mcleod steel flywheel and street extreme clutch.
Rear end and suspension is a 8 3/4 with 3.55s and a detroit truetrac, with freshened leaf springs and KYB shocks, on 295/50/15 cooper cobras.
So to get to the point, so far on a dragy I'm pulling 2.5 60ft times spinning through 60ft and my best 1/4 is 14.76 seconds at 96.53mph. Is this what I can basically expect at a strip, and would you guys have any insight as to how much slicks would improve my ET and would it be worth it?
Also, if I were to get tires, what would you all recommend, again sorry for the long winded post but I have very little experience regarding this field
Edit* forgot to add not sure if it was assumed but I also have Doug's long tube headers
Thanks
Thanks
. Its all about getting your 60 foot times down. 1.5-1.6 is what you are hoping for. Hard to get better than that consistently. You need traction. At the track you can get the tires hot in the water box which will help you hook up better. A line lock would help for consistency of burn outs. You can also shave off time by working on your reaction times. The 727 with a 3000 or so stall converter would also give you better times. With 96.6 trap speed you should be in the low 14’s /14.10 ish roughly with perfect RT and a 1.55 60 foot. To get into the high 13’s / 13.7 your trap speed will need to be 100 mph. You could lower gears to get that. 3:90
