Frankb
Engine is 440/496 with hyd roller cam and Crane Gold roller rockers. Engine assembled 12 years ago and has 2500 miles. There is a loud ticking noise coming from top end. I removed valve covers and found some loose rockers:
#2 exhaust
#6 intake
#6 exhaust
#8 intake (#8 exhaust valve is open)
Questions: what is the proper way to adjust roller rockers with hyd roller cam? Is there any way to determine if the lifters are bad without removing them? If the lifters won't pump up will that cause loose rockers?
The engine runs fine and makes good power. Top end oil lubrication looks good. Lifters are Gaterman GP1006. I ask about the lifters because this car sits for extended periods of time. Six months or longer.
#2 exhaust
#6 intake
#6 exhaust
