Exhaust mods, low tech
Unkle Krusty
4:51 PM
Gabriola BC
Stock 318 exhaust manifolds. Right hand side had a flapper valves with a spring, to help with cold starts.
So, I removed that and plugged the holes where the shaft used to be, with two bolts.
Noticed the centre ports are not flush smooth. I will buy a new file and attempt to make this area smooth again.
Can post a pic later when it is dark to show indent more clearly.
Don't worry about wasting time filing. You will never get a straight surface. Just use Fel-Pro exhaust manifold gaskets with the metal side to the manifold and you will be fine. I also spray copper coat on both sides of the gasket.
Thank you 69Bee.
Have you seen my question about valve stem seals.
Posted it under an existing tnread of mine about Valves.
For 69Bee. Just putting the stock manifolds back on.
Metal side out, or towards the manifold.
Sorry, cleaning out the "P-Trap"... Metal side out to manifold and I copper coat both sides then let tack up for about 5 minutes before installing.
