catfish774
I'd like to hear from those who have used an external oiling system for the RB engine. I am looking at a 440 block that has had the oil pick up drilled out at the wrong angle. Don't want to buy a boat anchor!
Direct from ad:
"This is a 76 model 440 block. This has been bored 30 over all machine work is fresh motor was run for 500 miles pulled out of car and decided to go a different direction. Only problem with the block is you must run an external oil pickup due to being drilled at an incorrect angle and the pick up tube will hit your rods due to this incorrect angle"
Direct from ad:
