Fan/PS Belt sizes - 66 Satellite Hemi
Bleep Bleep
11:15 AM
Pittsburgh
Gentlemen. Rock Auto has 3 sizes for power steering belts. (AC Delco)
• 43.75 x 50.5
• 41 3/8 x 46 5/8
• 39 3/8 x 50.5
I’m a no A/C car. So I’m assuming the 46 5/8 inch belt is prob the one? Any info to help me prevent getting the wrong one is appreciated.
There’s only one alt/fan belt from Delco and it references Hemi so prob safe enough on that one. But advise if you think otherwise. Thanks.
I’m having a hell of a time fitting new belts on my 66 Hemi that I just converted to PS. It’s mostly my own making as I have a preference for Dayton Top Cog belts and I can’t find them locally. The one I have got to fit closest on the pump so far is a 15395 belt (39.5”). But it’s at the end of adjustment and not able to be tensioned as much as it should. Probably another 1” shorter would be fine.
BUT - it depends on your pulley sizes and my TRW pump pulley could be different from yours.
All 6 years of the Street Hemi used the same pulleys and ps belt. The PS belt is the wide 17 series belt. I have a few NOS Mopar Hemi PS belts. PM me for more details.
Do you have factory Hemi pulleys? -the PS belt should be wider than the fan belt.
Not sure if you can tell from the picture if my pulleys are original. From checking around I believe the os pump is TRW. Both belts are same width. Changing them out since it’s a new ride and I have no history at all - cheap investment. Thanks.
Take a couple close up pics from the driver side showing the fan and ps pulley with belts that you have. The ps pulley should be quite a bit wider than the fan pulley. Try to get a pic of the crank pulley also. Call my number in the PM and we can discuss it farther.
Sorry. Guess these would help. :jackoff:
Let me go to my desktop to see larger pictures. It appears you have the correct pulleys. Your ps belt says 17415, but looks to me to be a 15415. and your fan belt appears to be the 15 series belt also, which is not the correct width. PM me for more details.
