I've been looking for the same thing... Nessie, Bigfoot and a politician that doesn't spend; would be easier to find. When I started my project i bagged all the screws individually by area, (ya, I know) and will buy replacements for each application as needed. Short of it, no kits put together that I have found. Good luck with your search...
There are sellers on fleabay that sell all kinda small screws like interior fasteners and stuff. Like sill plates and all for example. You just have to know which size you need and finish and all that hooha. I don't know if you've looked there or not.
Well as far as the smaller stuff such as the headlight bezel screws and clips i was able to find the clips at my local parts/body store. I bought the stainless screws at lowes. The bolts for the hood latch, and the piece that goes from fender to fender that holds your hood adjustment rubbers...again parts store. Fender, hood hinge, door hinge, trunk hinge and trunk latch i bought from R/T Specialtys. Truth be known i could of bought those at the parts store too but they had the proper clips for the fenders and the correct bottom fender bolt that is actually a stud with a nut fot proper fender alignment. All clips and screws for front and rear glass trim i got from Kramers. Hope this helps. I also have acomplete 4 door car in case u need a photo of a specific area.
There is a seller on Ebag that sells complete interior and exterior screw kits for these cars. i bought one for me and one for my buddy and his 65. Everything is numbered and labeled. I can't remember the seller's handle right now tho. They were very good kits.
