BenH
The car is a 65 satellite. It had a 361 in it originally, but I put together a 440 for it and swapped them out. In the swap, the oil pan issues which are common with this car arose and I used the original 361 B block oil pan and pickup because it was the only option. This is a particularly shallow pan and I believe is considered 4 quart capacity, so that plus a filter quart brings it to 5qt total I assume.
Questions are:
Is that the correct capacity, in your opinion should I use a bit more?
In your opinion, will this setup suffice on a 507/510 cam 440 with bumped up compression? Not racing, cruising and having fun.
thx
Questions are:
thx
