BamaCharger66
I meant LOWER RIGHT
That should feed the horn relay.
Thank you!That should feed the horn relay.
The.Relay youre pointing to, should have a Bolt where the mess is. A nut secures Pos batt cable, voltage turns around there into BulkheadTrying to figure out wiring on my ‘66 Charger with its ‘65 413 that I just installed. My other ‘66 Charger had an obvious bolt that my battery’s pos cable terminated to to ultimately power the car’s ignition and dash/lights/horns/etc.
I don’t see the same type termination point on this ‘66. Where’s that post/bolt?
