Doorkicker
Got an odd one for you. 1967 Coronet 440. Everything is fine with the car, drive it all the time.
And then...
Went for a drive a noticed the emergency brake indicator light (the light on the bottom left of the drive's dash that comes on when you press the emergency brake peddle) was flashing. And not flashing like there's a weird, loose connection or something - but rather just like a turn signal.
Troubleshooting procedure...
#1 - Pulled release handle to confirm the emergency brake was off.
#2 - Put the brake on to see what would happen... no change. (Note.. I don't use the ebrake because it's disconnected)
#3 - Check switch and wire to ebrake peddle - looked fine/normal. No change if I actuated the switch.
#4 - Turned on turn signal to see if they flashed at the same rate... nope. Different rates and pulses.
#5 - Turned on hazards to check flashing rate... nope. Different rates and pulses.
#6 - Pressed the horn... just in case, you never know. And I wanted to say "hi" to my neighbor.
#7 - Got board, turned car off and started working on my other car.
Before I start chasing this gremlin... I wanted to see if you fellas we're like "Oh yeah, that happens all the time, just do..."
Back story...
Started about a month ago. I've owned the car for about 2 yrs., got as a fix-er-up-er.
It used to have a water leak at the base of the windshield on the driver's side, which looked to be quite an issue before I got the car. I have corrected, but no debating there was a leak and water was coming out from under the dash.
No other electrical issues with the car since I've owned it. Taillights work, turn signals, head lights, and even the dome light works. Nothing else flashes (that wasn't intended to flash)
And then...
Back story...
