Mariposa Mike
To Twecomm... The blue (gas tank) does show the same resistance as the pink wire. None of the others do. So somewhere that pink wire is grounded. Looks like the transition to the upper interior lights is a yellow wire. I'm also going to see if I can access that wire before removing the seat. Maybe with the console lid and box removed. Still don't know what that green wire is for and need to trace that back. It might be in place of a yellow. Likely zeroing in on this. I believe at some point the carpets may have been changed. They look pretty good in most areas. Might be an ooops under there.
