Flat tappet lifter idea
Moparfever65
3:46 PM
Sacramento
Just saw this video, thought i'd share. Sounds like a good alternative to new ones. I have not used their services, just saw their video.
Makes perfect sense to me, start saving all those old lifters
In the 70's Tech School our valve grinding machine also had lifter resurface as part of the machine.
Not sure of brand. Maybe a Sunnen.
Makes sense to me....anyone have any experience with this?
Good idea. Proper lifter surface and lifter bore prep are very important. Lobe taper is also very important. If I were to do another cam I would sure check everything out very carefully before assembly.
You can grind your own groove down the lifter body using a Dremel with 0.025" cut off wheel. Been doing it for 30 yrs....
