Why have the car companies gone to the extra exspense to install roller lifters in their motors?
Most modern day cars (since the 90's) have switched to roller cams due to reliability and ease of use. Roller cams require roller lifters.
I just need to make sure I can find a set that are oil-through lifters otherwise there is no point lol.
Hmmm... I've been thinking about this lately too. Its tempting to go all out performance (rollers) but that not really the aim of my build. I want it fast but not a 9sec warrior. I'd like a good rough lope. I was thinking of rollers to avoid the run in, but if the rollers don't sound as good then I might have to go flat tappets.
Probably a stupid question, Flat tappets with roller rockers? Any point?
Sorry I'm new to old school, I can talk DOHC, but push rods are another thing!
From the research I have done (who knows it could be wrong) you can't use roller lifters with a flat tappet cam. But you should be able to use roller rockers with any type of cam if I am not mistaken.
Sorry guys,,,I don't buy it..... The sound of the engine isn't derived from the type of material the camshaft is made from "rollers are billet", or the lifter makeup "roller or non-roller". It is the (PROFILE) of the camshaft that controls the engines characteristics "regarding camshafts", and the sound generated. The design of a roller camshaft allows manufactures to design much more aggressive profiles without bouncing the lifter off the tip of the cam lobe.... or wiping out the lobe due to the needed high spring pressures on big lift profiles.
Not trying to cause an argument,,,,,,,, Just my 2 cents.
Very niceNot disagreeing with the above, but my common sense has to wonder what 'streetable' roller camshaft are you running that has 310-320* duration or 106 LSA...? I spent $200 on my camshaft and lifters from Mopar Performance, $80 on push rods, and $175 on crane ductile iron adjustable rockers that were NOS. You cannot duplicate similar performance for that price with ANY roller camshaft. Most 'off the shelf' roller cams are not very aggressive in profile. Spring tensions would be through the roof running a similar grounded' cam as the .590 solid from Mopar. I ran the .590 because it does not require 'sky high' valve spring pressures like modern camshafts. Flat out, nothing can beat the sound of a solid lifter camshaft... If you say a roller cam, then you have never had a solid lifter camshaft worth mentioning.. Just listen to this!
[video=youtube;4Ts6-qOglPg]http://www.youtube.com/watch?v=4Ts6-qOglPg[/video]
