66Satellite47
You can gain quite a bit of power by yourself. Pocket porting makes a big improvement. The 2.14 1.81 valve combination also helps. If you decide to go crazy like I did, grinding to intake pushrod lump gives you something. However grinding too far creates a hole. Epoxy can cure that. 906 or 915 heads can make good power. Pocket porting is the first step, with the best results.
