cwhubb
I'm having a problem with the idle on my car, I get it where I want it then when I rev it it idles way too fast. The linkage doesn't visibly move when I pull it back towards the return spring but the idle does slow down after a few seconds but it's too slow the car barely runs, again I set the idle where I want it the cat idles great but rev it and the cycle starts over. I had the carb off to re-do the jetting before I took it off I didn't have the idle problem so I know the return springs work plus they worked with the old carb I had on it. the car runs really strong under acceleration with out any stumble misses or back fire.Its a Holley 950hp carb, the initial power shot pump is set at around 15 using a feeler gauge any theories?
