- 1:27 AM
- Mar 14, 2012
- Surrey, B.C. Canada
Stuck to the side or end of just about every single rail car out there, this little device is called a 'retainer'. And that's what it does, it retains air.
The handle is normally down, as shown, which allows air to escape. This is where the air come out when the brakes are released and air is let out of the brake pistons. The purpose of the valve is to prevent release, which means the brakes stay on. This feature is used on long downhill grades where constant braking may be needed, such as a mine siding. Using the brakes means depleting the compressed air in the reservoirs, and adding air from the locomotive to refill the reservoirs also signals the brakes to release.By turning the valve, the crew can keep the brakes on while at the same time fully charge the train with more air. It does mean that one of the crew has to walk the length and turn each of those valves. There are three settings with notched detents; full release, full retain and slow release.
As shown, it's a black plastic valve. Back when I started, these were all a fairly heavy brass casting, not only costing a lot more but being a tempting target for metal thieves.
