Four wheel disc conversion on my 64 Polara
Glenwood
3:32 PM
Kawartha Lakes, Ontario
With a more power available than the old poly318 had, I decided it was time to upgrade the suspension and braking system on the ’64, now that I’m done with the sheet metal work, engine & cooling system (which took longer and cost more than imagined!) The single can master cylinder and 10 inch drum brakes felt soft and made me a bit nervous at times.
Without many options up here in in the great white north, though national moparts does sell a package for the front, I settled on Dr. Diff’s offering.
Wanting to do a 4 wheel disc conversion meant the rear end would need to have flanged styled axles instead of the original tapered axles available in ’64. I had already swapped the rear end with a ’70, but it was still a bit too wide for the 275’s in the wheel wells, even with 4.5” back spacing. However, there is enough clearance to the leafsprings for over 5” backspace.
I found a ’63 B-body rear end for sale locally and picked it up. This housing is approx. 1.5” narrower than the ’70. I ordered new axles from Cass as well. After checking the gears and replacing the front seal on the 3.23 741, I cleaned, painted and installed back on the 63 housing. The flange studs for the pumpkin were in rough shape so these were replaced. For the brake conversion, longer axle tube flange studs are needed, so these were replaced too.
Cass was able to pull these items together and ship them to me in a week, while I was in the USA on a business trip recently.
The front brake kit has:
· new spindles (73-76 Duster/73-74 Challenger). You have to reuse your two large mounting bolts.
· Rotors from a 78 Cordoba
· Calipers 82 Diplomat
· Hoses & Timken bearings.
I ordered new front SS brake lines, Mopar aluminum dual master cylinder with a 15/16” bore & 2 to 4 bolt adapter, distribution block, master cylinder lines
The rear end brake kit has:
· Aluminum caliper brackets
· Rotors for a Toyota Cressenda
· Calipers with E-brake for a 98 Cobra
· Braided hoses
· Optional New E-brake cables
I also ordered new 1.03” torsion bars from PST and a new 1-1/8” Hellwig anti-sway bar through Summit. Shocks to be ordered later as sourcing Bilsteins up here seems impossible.
Having completely dismantled, cleaned and painted all of the components on the car a few years ago, it was easier to dismantle this time.
The torsion bars came out without too much trouble using the tool I made, after the bottom bolts for the shocks were removed and the upper rubber bumpers were removed.
The front spindles came off easily and I was able to use my pitman arm puller to easily separate the upper ball joints. The knuckle, lower ball joint and tie-rod did not need to be dismantled further. After a little grease clean up, the spindles were installed with the caliper mounts facing rearward. Torquing the upper ball joint (125lbs) was difficult with the spindle unbolted. There isn’t enough room to get a socket and TQ wrench on otherwise. I found that it was easier to turn the spindle part way and insert only one bolt through the spindle and lower ball joint. This allowed more access and was much easier. Original knuckle large bolts and castle nuts (to back) were installed and torqued to 100lbs.
The rotors came with races installed made of fine chinesium. The dr. recommends replacing the races with the ones that come with the new Timken bearings. It was a bit tricky to pop them out of the rotor. I had a 1”+ SS round bar that was a perfect fit to pop out the outer small race, but the large one was more difficult. I used a large drift to pop it out without scoring the sides of the rotor. Installing the new races was easy using the seal/race driver kit I finally broke down and bought. The inner seal does not come with instructions and could go in either way. It’s been a while since I worked on these types of rotors, so I could not remember how to orientate it. It turns out the rubber portion is to stick out towards the knuckle to seal out debris from entering the bearings. These are a tight fit and could not be tapped in side to side. I found a large sleeve from my ball joint press fit the seal nicely.
Before I packed the inner bearings and installed in the rotor, I tried sliding them on the spindle. Good thing I did as they are too tight. I took some 600 grit and knocked the spindle diameters down enough to slide on the bearings with a bit of grease.
Pre-bent SS front brake lines fit nicely and assembly went smoothly, though the hoses were tricky to curl in the right direction to install on the caliper properly. I wanted to be sure they wouldn’t get pinched or rub on any sharp edges. I blew out the front to back brake line with compressed air before attaching to the distribution block.
The old master cylinder rod was difficult to remove. Mounted in a vice, the rod simply would not pry out of the MC, so I found a tire iron fit nicely through the rod’s eyelet, where a few taps with a hammer on the tire iron propped it free, squirting fluid in the process. The spring and boot were removed, a new rubber washer from Dr Diff was installed on the rod and inserted into the new MC. I installed the adapter and MC to check the rod length and it was perfect.
Rotors, bearings were greased, tightened, backed off and torqued to 90inches before installing cotter pins. The caliper brackets were installed using the button head bolts supplied, loctite and torqued according to Dr. Diff’s specs. The calipers went on easily, though DR Diff’s instructions tell you to bend the outer pad tabs with a hammer to snug them up and keep them from rattling. I removed the caliper sliding pins first to check/add silicon grease. I installed the brake dust shields and greased the joints. The calipers are very close to the 15 inch rim and trimmed off the stick-on balance weights inside the rim.
The new torsion bars are fat! I found the passenger side difficult to install, having to force the adjuster LCA pivot down a bit and then realized the headers that barely cleared the original bars are too close to the fatter bars. Some heat and encouragement opened up the space a bit on the passenger header. Looks like the pitman and idler are rubbing the headers as well under certain conditions, so these areas were massaged too.
No way the new seals would go on over the bars. I boiled water and let them sit in it, but they were simply too tight. The old seals were replaced a couple of years ago and I just reused them instead.
The rear was fairly simple, but the instructions are vague. Basically the pumpkin goes on first, the caliper mount adapter brackets 2nd without gaskets and facing rearward, then the axles. The adapter bracket holes have to face inward for proper clearance. I had them on backwards at first, since the instructions do not point out the proper positioning. On goes the rotors, caliper mounts and then the calipers. Washers are supplied to help center the claipers over the rotors. I found one side needed thin washers and the other side need the thicker ones. Bent up the brake lines to the new block and mounts on the caliper bracket.
Test fit the wheels...lots more room and looks better to me.
The parking brake cables from Dr Diff that needed to be ordered for this conversion did not fit right. The sheath was too long and the cable stickout was too short for the intermediate cable. No matter how you route the cable, the stickout was approx. 5/8" short, so the int-med cable equalizer wound not reach the front cable adjuster stud. I measured for replacement cables and Cass sent them free of charge, but I don't think he was too happy about it. He claimed that the spec for his cables always fit, but I have no idea why they would not work on this car with everything in stock positions. The cables seat only one way as the metal ends are different diameters, but you would notice this pretty quick when you try to put the c-clips on. The new cables I spec'd fit perfectly and placed the equalizer in the middle of the adjuster stud as I would expect. I took about 5" off of the jacket length and added a little to the steel cable.
Bench-bled the master cylinder and then the system. Cass recommends Dot4 fluid, so I went with that. They still seem soft, but I won't get a chance to test them for a few months once the snow is gone.
On to the sway bar...
The Hellwig 1-1/8" solid bar seems like a nice piece. The brackets and parts look like heavy duty pieces. I discovered the endlink bushings were all missing. Looks like someone ordered the bar, sliced the bag, took the bushings and sent it back to be resold. Lucky me. Summit was very slow to respond and took a phone call before they got after Hellwig to send me some bushings. A month later, they arrived and I went to work.
The rad support bracket has to be removed while setting it all up. The center bend is very close, in fact too close to the bracket and I will have to space the support bracket down a bit. With the car on its wheels, the right angled brackets are installed to the shock bolts (new longer ones)and then the endlinks. Trying to find the proper angle of the endlink brackets to properly center the bar is a pain. Once that is done and everything snugged up, the other bar brackets can be placed. These are left and right orientation. Drilling 3/8" holes upside down is always a treat!
20200131_165700.jpg 20200131_165732.jpg 20200131_165745.jpg 20200131_200322.jpg 20200131_200346.jpg 20200131_200322.jpg 20200131_200332.jpg 20200131_200353.jpg
Nice documentation job for the rest of us. Cass is the man, I wish I knew him and his parts 25 years ago.I think he may have been a teenager back then though..
Glenwood, I have followed you on your build. You have done a great job and you should be proud of it. Of course I'm alittle bias but truly appreciate your time to show us all how it is done.
Just put a front disc conversion on my Bee and wish Cass would have told me to replace the races on the rotor. To late now.....
You're too kind Barry. These parts are pretty simple to install, even for an old sparky like me. I hope they work!
Truthfully, I read it on a number of other posts from other sites, as it's not mentioned in the instructions. Otherwise I would have done the same thing, though it probably won't hurt them too much.
View attachment 903551 View attachment 903552 View attachment 903553 View attachment 903554
Glenwood on the front for the hose you got to use the stock mounting brackets.
View attachment 903556 View attachment 903557 View attachment 903558 View attachment 903559
View attachment 903560 View attachment 903561 View attachment 903562
I have a thought what's your input. I'm going to put 3m clear gravel guard on the panel that flattens out behind rear wheels.
Thanks for sharing Glenwood! I might do the upgrade someday but I'm good for now. I like dealing with Cass. He's really helped me out in the past and just recently.
I have a sweet spot for the '64s. My first Mopar when I was 18 :D
