- 11:45 PM
- May 14, 2011
- On the Ridge, TN
Thanks for the lesson! Hadn’t seen that one before. I can do custom ones, but would need to do a small bulk. Would probably be $80 to get it going. From there I’d be able to have an over run that I can put on eBay and maintain stock.Yup or this one:
The fratzog is the emblem pictured. Used by Dodge.What the hell is a "fratzog" ???
Packed up and labeled the next round of orders, going out on Monday!Just placed an order on ebay for two. A car I'm trying to buy has the same grant wheel as your picture. The car has a black interior so this emblem would look alot better then the blue one on there. Thanks
In theory these could be used for that purpose as is if you are ok with the 1.5" diameter. They have a strong adhesive, and the epoxy dome is pretty UV resistant. Just keep in mind, I have not tested them on the outside of a car personally.I would be interested in the magnum 500 hub cap emblem as well. I measured 1,81“ in the original hub caps. The reproduction have 1,77“.
