themechanic
Oklahoma is OK
- 11:23 AM
- Nov 11, 2012
- Moore, Oklahoma
They did a road test, as most of us are able to do, comparing three similar cars with different suspension systems drivingthe samecourse with each one. One car had a stock suspension and two were modified.Is this one of the three B body's that did an IFS "soft" IMO lame on road video comparison on with aftermarket track and pinion/coil overs a few months back?
I've personally done this with A and B bodies from KYB to Bilsteins and will always. I also did PST torsion bars. Huge noticeable difference.Next video will deal with a comparison of KYB Gas Adjust and Bilstein shocks. I personally have done this on my stock 69 Coronet suspension and found no noticeable difference in ride quality. Certainly, not enough to justify the expense.
The road test was lame. It was just some dude making a casual drive and commenting on it. No slalom to compare body roll, no stopwatch, no skid pad, no course with undulations to assess ride quality.They did a road test, as most of us are able to do, comparing three similar cars with different suspension systems drivingthe samecourse with each one. One car had a stock suspension and two were modified.
I ran brake torque numbers on every combo from stock 11" to the 11.75" a couple 13" setups, and up to the 14" 4 piston Wilwood. The winner... the factory 11.75" setup. Now I realize that for racing there are heat management and pedal feel issues, but for a performance street car, I can't see spending the several grand for Wilwood/Baer etc.The MF? Wilwood brake selection is something one might see on early Slant 6 A body, and was without a doubt a poor choice, and easy to correct and have a much better solution than any OEM disc package intended for performance use. The brake rotor warping concern voiced here is debatable.
Best brake torque with less than a 6 piston caliper is the factory 11.75", that's going to be the best performance, at least for a single stop. And ya, "brakes stop the wheels, tires stop the car" is absolutely true. So on that end you're 100% correct.You likely are correct, bang for buck, Oem is best deal. Performance wise not so much. Regardless, the ultimate goal is stopping one's car. and brakes only stop the wheels, tires stop the car, and are often most likely stopping determining factor.
