My main goal in my front suspension replacement/upgrades was greater adjustability to be able to have it dialed in "just right", overall appearance and designation as a "Resto-Mod/Pro Street" vibe, and better overall performance.
My focus is quarter mile drag racing performance and cruising on the street, not "corner carving".
I believe it's accurate to say that using the QA1 front suspension components is keeping the factory engineering design, but replacing all of the parts with modern upgrades.
NOTE:
I used ALL QA1 parts in my front suspension replacement including the K-member, EXCEPT FOR a key component:
The upper control arms (UCAs) are SPC and the reason why is lack of adjustment range with the factory "cam style" UCAs don't allow enough range for my car, and I had 2 different front end alignment techs say so.
@BergmanAutoCraft had a nice in-house tweak to the SPC UCAs that is specific to MOPAR, but SPC also just recently changed the design of their UCAs, which I read about but honestly I don't understand.
I got the SPC UCAs in my 70 Roadrunner from SPC for MOPAR, and they have worked fine so far.
@BergmanAutoCraft
Would you be kind enough to describe the advantages and differences between your SPC UCAs and the "stock SPC UCAs" (if you have any left to sell) and the differences with the new design SPC UCAs for MOPAR please?
Just seeing this now as I'm not getting email updates for some reason.
SPC has been making control arms for the Mopars for some time now. However, my testing shows the rubber bushings provided in their arms do not offer enough of an interference fit to stay put when loaded through cornering and braking. I adapted their delrin mounts using custom made sleeves and spacers. They mount properly and solidly now on Mopar applications. Nobody else does this as my competition are simply resellers. Most if not all have ever touched these arms much less evaluated their function. I still have these if anyone would like a set which is why they are still on my site.
SPC redesigned all their arms recently and went to a forged design and uses a proprietary ball joint that is taller than the traditional K772. This offers reduced body roll as the moment arm is shortened slightly. The new design is on car double adjustable and appears very robust. I am not sure why they went to this design.
