Which parts are you curious about?
Not completely sure. Possibly the tie-rod ends getting thicker?
Did you paint your front end parts to duplicate factory markings and such?
I rebuilt my entire front end. I bought complete kits ( individual available ) from PST, Performance Suspension Technology. www.p-s-t.com. They offer original & polygraphite. Great customer service 800-247-2288. Free catalog.
I did not. I tried to stay with what would look reasonably original without trying to be original. Also I wanted fairly durable finishes. I didn't finish the lower arms as the factory received and installed them. Most everything I painted with semi-gloss black or cast iron finish paints.
Which paint did you use to give that cast iron look? Or am I mistaking that for primer?
I think I used Plastikot Cast Finish on it. But sometimes I've used Eastwood chassis paints like Detail Gray. I've learned to first apply a light to medium coat of a black rust-resistant primer first since many of these detail paints are (or were in the past) lacquer based and not too rust resistant.
I rebuilt both front and rear suspensions at the same time and sandblasted everything myself which was a pretty big job with a small pot sandblaster. However, it was the rear springs that about finished me off so if you are sticking to the front end for now that's not too bad. if your components have a lot of rust or scale on them and you aren't set up to sandblast, you might want to consider getting a quote from a local powder coating firm. In the past, the cost of sandblasting and powder coating was pretty comparable with what I had in it considering my sweat labor. Sometimes they have a limited selection of colors but they usually have a semi-flat and gloss black and something that will pass for a natural cast finish.
And I imagine the powdercoating must also be more durable than anything we can do on our own.
What did you do with the rear suspension? My next project is to rebuild (not re-arc) my leaf springs, and then fix a few things on the rear end before I repaint it.
Powder coating is a lot more durable. The only drawback to me is if any of your parts are pitted in a visible area, that will show through the powder coating. I'm not aware they have come up with a process to economically fill pits before coating. I had one upper a-arm that after sandblasting, it had some visible pitting down in the folds of the metal and I primed it and then smeared a coating of body filler over it to fill the pits and sanded it smooth before painting.
On the rear I pulled the rear end, springs, hangars, etc. Although I used all rubber in the front suspension (except for the tension rod ends) I used poly bushings in the rear. I put a new sure grip and gears in so I stripped the rear down to a bare unit and blasted it, painted it and installed new axle seals. The original tapered bearings looked and felt good so I kept them. I took the leaves apart and sandblasted them, painted them, installed new friction pads and clamps. I also installed new shackles in the rear. I had a hard time finding original appearance shackles but someone referred me to Bill Rolik Enterprises who had them and several other hard to find pieces. While I was under there I also put in new fuel and chassis brake lines I've had up in the attic for years. The only real pains in this were a fair amount of sandblasting and I was real careful to keep the spring leaves for each side together and oriented the same end for end. I was constantly worried about getting them mixed up or turned around and have a real puzzle to figure out.
There was one other issue with the rear which was setting up the new rear end. It turned into a 6-month long saga involving having to pull it and reinstall 4 times to be set up and 2 new sets of gears. If your rear end is a good ratio for your use and seems to be in good shape I would leave it alone if you can. I farmed that work out to the local go-to vintage car mechanic around here and he was a slave to Richmond Gears. I think it's the Richmond Gears that were the source of most of the problems. Even now it's still not completely quiet.
Usually (maybe not always) rear wheel bearing (or outer axle shaft bearings) noise is pretty easy to isolate as it gets a lot louder in a turn where a side load is put on the bearings. If you have noise driving in a straight line that doesn't change in a corner - might be your rear end.
Ya, I've tried that but haven't noticed much of a change. What I'm going to really do to isolate the noise is jack the rear up, and put the car into fourth, and just let the wheels spin. I'll go under and put a stethoscope on the rear by the berings and see if I can hear any weird noises. I bet I will.
But I also hear noise going in a straight line, so I have to figure out if that noise is either the rear's main gears, or a driveshaft issue. I've checked the driveshaft joints, and there is no movement. But it could still be out of balance...
Read post #7 by Bill Rolik. I bought my suspension parts from him.
http://www.forbbodiesonly.com/moparforum/threads/raybestos-or-moog-ball-joints.50256/
See my post #6 here for video on quality http://www.forbbodiesonly.com/moparforum/threads/lower-ball-joints.82763/#post-910169391
