cubanmoparnut54
- 8:19 PM
- Apr 26, 2024
- Los angeles (soon to be arizona)
Hey guys I just finished painting my 71 RR tribute and I am getting ready to re-do the front suspension. Rear-suspension has been rebuilt with stock leaf springs new rubber bushings and a 7/8 rear sway bar with poly bushings. Shocks are brand new. Front sway bar is stock with new rubber bushings. I have new tubular POL upper control arms, LCA boxing plates and poly bushings, poly bushings for the strut rods, new lower balljoints and tire rod ends, fast ratio idler arm, Stock 318 torsion bars and 16:1 manual steering. I'm debating if I should change out the torsion bars and put in poly bump stops vs rubber ones. Want to make the car handle as well as possible. Any advice would be appreciated thanks.
