Front spindle question
clazar
7:20 AM
Pittsburgh
I have a 70 RR with frt power disc brakes. My question is what front spindles will interchange to my upper & lower control arms.
Chuck
1970-74 E body,
71-72 B body,
73-76 A body have the same size spindles.
The later years B F,M,J bodies have a taller spindle but it will work.
Whats wrong with your spindles?
1970-74 E body,
71-72 B body,
I have new inner & outer bearings for what I thought was 70 rotors. But when I went to change them, they didn't fit. So I suspect the spindles were changed at some point. Ans some other year rotors were added also. But will a 70 rotor fit any of the other spindles ??
The 70 rotor has a smaller inner bearing and will only fit the 70-71 spindle. What bearing numbers were in the rotors before you changed them. Can you post some pictures of the spindles and rotors
