hemidale
New Member
Car is a 66 Coronet with factory hemi and 4 speed. We just now fired the car up after many years of sitting and everything worked as it should when it was parked. Now the fuel and water temp gauge don't function at all. We tested the internal voltage limiter and tests say its ok(get fluctuating voltage with a multimeter and test light blinks when hooked to either of the gauges).
The engine was out of the car along with gas tank, rear diff, k member and anything else you might think of. Is there something that we might have forgotten to hook back up that we are missing? Everything in the car works as it should but these two things(oh, and they were replaced with new parts).
I know new parts don't mean good parts but everything points to the voltage limiter but it checks good. We even had a couple of spares around and they tested the same. We're thinking we just missed something simple and looking for a brain jog. Thanks.
