ilm65
I'm running an Edelbrock pump #EDE1723 (for big block) from Mancini Racing (go to their website under Fuel). It has both 3/8" inlet and 3/8" outlet and can support up to 600 hp; works beautifully for me! And yes, it will fit a 400 block. Also, you asked "What kind of power is a stock pump good for?" First, you typically don't want more than 7 lbs. pressure going to your carburetor(s) because too much pressure will simply overpower and flood your float bowls. Anything beyond 8 lbs. requires a pressure regulator. The EDE1723 puts out 6 lbs., but flowing 100+ gallons per hour (gph), thanks to the 3/8" inlet and 3/8" outlet and internal pumping capacity, it'll support big horsepower.
Good luck!
Good luck!
