If the temp. and oil pressure work correctly the voltage regulator is not the problem.What was your gauge doing if I may ask?
My gas tank readings were dead when I got it and previous experience tells me the insides of the tanks are a nightmare, so that isn't surprising. The Temp worked, then quit, but I did replace the water pump, thermostat, and hoses, so I may not have plugged the sending unit back in. While I have never had a CVR go bad, I will be swapping out the pitted gauges and the replacements probably have a good CVR, but while it is apart, I will replace with new. The next cheapest CVR I found was $100What was your gauge doing if I may ask?
Check one more thing if you get an opportunity......FUEL gauge will litterly show its over half a tank and or 3/4.After a little bit of time it shows way under Empty? Brand new sending unit and I already checked wires. Anybody ever had this happen? Could this be the IVR in dash being out?
Here's a solid state alternative: RTE limiter - rteI have learned a little about CVRs recently with my Scout 800. I have to admit I didn't check the sending unit plug to my temp gauge and the tanks haven't been used in 30 years, but I found a nearly non-existent CVR for only $33 delivered, so I bought it. I'll change it out regardless as when they go bad it can be bad.
I read about those, but with my limitations in electronics, I understood them to be a steady 5 volts. The CVR fluctuates with a voltage that hovers in the 5 volt area, but not exactly. Some people get weird or inconsistent readings with electronic, so I found vintage OEM.Here's a solid state alternative: RTE limiter - rte
They dontIf the temp. and oil pressure work correctly the voltage regulator is not the problem.
I still have my old sending unit. This one I put on 2023 less than 10 miles on unit. I can plug my old one in and test that theory though.My gas tank readings were dead when I got it and previous experience tells me the insides of the tanks are a nightmare, so that isn't surprising. The Temp worked, then quit, but I did replace the water pump, thermostat, and hoses, so I may not have plugged the sending unit back in. While I have never had a CVR go bad, I will be swapping out the pitted gauges and the replacements probably have a good CVR, but while it is apart, I will replace with new. The next cheapest CVR I found was $100
Nice work Lee.My 69 Bee with Ralleye dash had the same fuel gauge issue even with the extra 10 gauge ground wire from sending unit to frame. Sending unit is a Spectre, made in Mexico unit. Only after I pulled the instrument panel and cleaned the gauge circuit board etchings with a brass wire brush and retightened the gauge lock nuts does the fuel gauge finally read properly.
Nice work Lee.![]()
Sure. Just need to logically diagnose it so you do not waste your money on parts that wont fix the problem.Changed the cvr still doesnt work and when you ground it doesnt go to full. This gauge has to be bad guys. Its like nobody has ever had a bad fuel gauge befoee.
