Yes find the steel on the sending unit and ground that, depending on the quality of the ss real ss should be able to hold a magnet mixed stuff does not this is why some refridges are $1500 and some are $600. It's possible to sand a spot on the ss down to the core steel.
Stainless is about 10 times less conductive than carbon steel but is not enough of an issue to make a difference; the sender's minimum resistance is far, far higher.
Looking to switch over to a electric fuel pump. Any suggestions? Also I would have to remove stock pump and use a plate? I have a vapor separator ( v code car) can I still use that?
