Looks like a nice 5 valve pump. can't believe that isn't providing you plenty of fuel, unless one of the inlet check valves is leaking and the pump stroke pushes some fuel back to the suction side.
Take line loose from carb and stick it in a jug. Start engine. Then you can see how much fuel the pump is pumping into the jug. Make sure bowls are full first, engine should run for at least 30 seconds before needing the extra dribble from a container.
