Fuel return line plumbing.
Wallus57
6:04 PM
Alberta
Hi folks. Has anyone plumbed their return into the fuel fill pipe? It's a lot easier than dropping the tank to drill the sending unit and I won't have access to a garage soon. I'm a little worried about a siphoning effect while filling the tank too.
Thanks, Wally
Not an expert on this at all, but I've read somewhere that the gas becomes bubbles if you go through the neck vs the sender. A return vent is different to the neck, but return fuel line to the neck is where I read this -- this could just be incorrect info but passing it along. I've had a 3/8 sender with the 1/4 return line on my shelf for a year until I get around to doing this officially. I stopped because I can't seem to find a repro sender that returns the correct resistance for my gas gauge. If you have success, please post your findings. I would love to see your solution.
Look for a "dolphin" fuel gauge adjuster. I just installed one, but haven't calibrated it yet, so I can't swear it works. It's small and has buttons inside & a screw adjuster.
Is it for fuel injection or mechanical pump on carb? FI will flow a higher volume and psi and "possibly" cause a little aeration. If it's mechanical pump from carb, it'll trickle down fill tube to tank and be just fine.
Thank you. I'll let you know but it'll be a month or so because I'm moving.
Thanks for the information. It's a mechanical pump.
Awesome! Thanks!
Ahh! That makes sense! Efi will bubble and mechanical is trickle. Maybe I’ll go the filler neck route as well. Thanks!
Thanks, Wally
what car is it for - meaning, is the filler tube behind the license plate at rear of the car or rear side of car like the Charger?
