awhile back I switched to a new fuel sender in my 67 coronet, the old one had a leaking float.
Now when I fill the tank It reads 1/2. When I run it down to empty I still have aprox 8 gals left in the tank.
Sender is working just not adjusted correctly. Ive been using it like this for awhile just running on the top 1/2 of the tank.
Is there away to adjust the reading ? bend the arm ect.
I figure I mabey need to bend the arm up a little so it rides higher in the fuel once the tank is full.
Does this sound right to you guys ? or do I just have a crap aftermarket sender and need a new one ?
I did search the old posts but didn't see one for the 1/2 tank reading when full and how to adjust it out of that.
Thanks for any input.
