I think I have the solution to everyone's problem. We run into the same problems that everyone else in this forum is having. Fuel gauge would only show a partial reading no matter how full the tank was. Sending unit out of the tank would work fine and show the proper ohm readings, but get it into the tank and the gauge would show a improper reading. After three sending units and many sleepless hours, we finally took the tank out again and did some testing with a different approach. Instead of worrying about the ohms, we decided to take a good look as to what it looked like inside the tank itself. We set the tank on a table, took out the filler tube, and shined a flashlight into the tank. Just as we thought, the sending unit was above the bottom of the tank by about 2-3 inches. I'm assuming that the mounting angle of the tank was made improperly. What we did next is carefully bend the pickup tube until the filter and float were just barely off of the bottom of the tank. This is a bit of trial and error to get it right, but isn't too bad. I wish we had thought of this sooner to eliminate all of the headaches and time wasted. This cured the problem of an incorrect fuel gauge reading. It works great, now.
We ended up using a Spectra tank and sending unit. As long as the ohm readings are good out of the tank, everything should work fine after you bend the tube down.
