Acworld34
1970 Plymouth Satellite
Me and my son were changing out the terminals and had my son put in a new battery.
The negative and positive was hooked up wrong and the fusible link started smoking so I disconnected immediately.
I hooked the battery up correctly and turn the key and nothing. checked all the fuses and all were good. The instrument was already out because we were changing the bulbs in the panel. The black and red cable are still hooked up to the instrument panel and currently the panel is still in the car hanging.
I just went ahead and changed the starter relay and was doing test with the voltmeter to try to trace the burnt wire/fuse. I hooked up a remote starter gun under the hood to the starter. The car starts and runs with the key turned in the on position when I use the gun. But when I just turn the key the car does nothing.
The Fusible link looks like it was soldered to another wire that runs through the Harness and fire wall. I'm not really able to trace inside the car because A/C & dash are in the way. With the voltmeter it does looks like power going from the starter relay into the wire harness.
Any ideas on where I can find out what is burned out? Do I have to take apart the whole dash to see the other side of the inside fire wall ? If I do I don't even know where to start.
The pictures suck as I took them in with my phone. first picture you can barely see the soldered wire. Pic at the bottom was originally how I got the car with the wire soldered and a black piece of electrical tape.
