soundhd
In case anyone might be interested (been looking for info for the wiring to make the hood lights work on my 70 RR) I Found these photos of the hood mounted turn signal wire harness and the connector on the forward light harness for the hood lights (these are off 69 Charger but assume they are the same)
Cables In photo #3 connect to harness in photo #1 which connects to connector in photo #2.......walla.....the hood mounted turn signals should now work.....if you can find all the parts, and if the turn signal lever works, and if there are no shorts/opens in the wiring, etc.........
Photo #1: Harness that connects the wires from the lamps to the main forward wire harness
Photo #2: Connection point on forward wire harness
Photo #3: The hood lights with wiring
