grasshopper
Ok like title says I have a 74 Charger with a 440 with a Holley 650 double pumper. When the engine gets hot it wants to flood out by pushing gas out the top vents. The car has a stock mechanical fuel pump with a Holley pressure regulator adjusted to 5 lbs. I am running 2 large inline filters. I have wrapped fuel lines with heat shielding material, and put a wooden spacer under carb. I also replaced the valley pan gasket with the Felpro one that blocks off exhaust crossover. I have removed the gas cap while ideling and it still floods out while hot. I'm out of ideas any help will be very appreciated, thanks. Oh and yes I have adjusted the floats many times even setting them a bit low,and even changed needle and seats.
