383man
Frank have you looked at a factory service manual to see just what your car used to vent from the factory ? I ask because some years did not leave room in the gas tank for fuel exspansion as some used a liquid vapor seperator that was not part of the tank but was in the trunk-1/4 panel area as it let the fuel go into it and then vented the fumes either to the eng crankcase or a charcoal canister. The fuel that was in liquid form the liquid vapor seperator drained back into the tank. Also I am guessing you have the right filler neck on the tank as the filler neck will stop venting when the full gets so high and cut the station pump off when filling the tank. Some cars do that so the tank has enough room for the fuel to exspand as thats why the filler necks have the smaller line on the side of them. If it had the wrong filler neck and did not shut the pump off at the right time it could fill the tank to full and leave no room for fuel exspansion. Ron
