markbob
Hello All....
I have a 69 Coronet with non ralleye dash.....
I checked voltage limiter function at fuel tank sending unit with a test light.....I get a flashing light....
I checked voltage limiter function at temp sending unit with same light....I get nothing....
I placed a jumper wire from sending unit wire to ground.....temp gauge needle does not move....
I checked all wires behind dash....especially those leading to the round plug in center of instrument cluster....nothing seems amiss....
I checked wiring diagram....and the temp gauge and fuel gauge share feed from voltage limiter....
How is the cluster grounded? Is it through the dash itself? My headlights, instrument cluster lights, emergency flashers all work.
My steering wheel is not installed, so the harness connections to that are not hooked up....
if I place a jumper from the ground to the fuel gauge sending unit wire, and the fuel gauge needle moves, then does this mean I need a new temp gauge?
Any thoughts?
thanks,
Mark
Any thoughts?
thanks,
Mark
