jason79
Need some advice from people with more experience than myself. Currently running 3.91 sure grip. The problem is 2 fold. First the sure grip is wearing out. Second I drive mostly highway. Rural Illinois closest town is 15 minutes any direction. I have a 489 case that I have cleaned up and ordered a rebuild kit for with a auburn limited slip. I have a set of 3.23 gears in very good condition that will go right in. Is this a good ratio or should I look for 3.55 gears? Engine is a 512 stroker with 9.5 to 1 compression. I have stealth heads, Howards hydraulic roller cam .545 lift, Hughes 3200 stall converter in a 727. I have not run it on a dyno, but would guess 525 to 550 for hp. I want better highway cruising rpms, but still want that low end performance of the 3.91 gears. Am I going to be disappointed with a 3.23 gear ratio?
