jball1105
Ok, I am going to once again show my ignorance....I wanted to find out what gears I have in my 63 Sport fury. I jacked up the rear end and spun the driver's side wheel. I knew that if the other wheel spun the same direction=sure grip, opposite direction=open gears....well what does it mean if the other wheel doesn't spin at all? Next to determine gears I was going to count the drive shaft rotations to one turn of the wheel, then I remembered I hadn't put the driveshaft back in yet.
I've been reading about EFI (looking at Fitech) and their instructions had a large caution about the necessity of proper venting of the fuel tank. Looking at my gas tank/sending unit (from spectra) I can't see how this is vented. Am I missing something that needs to be installed?
Thanks for all your help.
