Geez I hate that ..... broke an expensive tool
kiwigtx
International Mod of Mystery
Staff member
12:54 PM
New Zealand
I was clearing out my small tool carry bag just minutes ago, when I heard a noise nobody likes to hear. The Harris D814 Punch-down tool that I have used since about 2010, dropped on the garage floor and the case just shattered to bits. No amount of Superglue will fix this - the pressure exerted on the tool to make it function will easily break any glue-job.
I have sent an SOS to a Tool House I found online....as luck would have it, nobody in New Zealand sells the same tool. I don't like buying cheap stuff, so I am going to wait and see if I can replace with the same tool.
Case is cracked in about three places.....it is toast now.
:xscuseless:
There are 2 on ebay for under $20 right now. In yellow.
Edit: I changed the search terms and there are a ton of these on ebay as low as under $10. I did not check any descriptions, punched in Harris D814.
Too bad it's not round like this Durango Rear AC flapper door. You could glue it then press a sleeve over it.....
It's obviously the synchronization tool needed to maximize efficiency in turbo encabulator applications. It's sleek design and ergonomic improvements over the old 813 model are welcome improvements.
I was going to , but I'm cracking up and can't.
Just my opinion ok. :rofl: :rofl: :rofl:
