Gen III Hemi engine builds
rolling_Thunder
1:47 PM
NC
Not sure if there is an existing thread for proven engine builds concerning the Gen III Hemi but figure it would be a decent resource as there is nowhere near the information out there compared to say, LS engines. I am currently building two Gen IIIs
Engine 1 - Stock 6.1L Hemi that has been in my 68 Charger since 2008. Running an LS throttle Body and used to test and fit everything way back before there was aftermarket support for the Gen III hemi swaps. TTI headers fit like crap and required clearancing. Engine is currently bolted up to a older Tremec TKO 5-speed swap.
Engine 2 - This engine was to just utilize some parts I have laying around and to see what cross application for parts could be done. Essentially this engine is a stock 6.1L rebuild but I scored a complete set of Hellcat piston and rod assemblies. I wanted a spare short block that could accept some boost - so the factory hellcat stuff dropped compression to 9.5:1 but utilizing a 0.027" thick head gasket brings it to 9.75:1 - it is currently assembled but has not been dyno tested.
Block: 6.1L Hemi 05037388AB
Stroke: 3.58" (Stock 6.1L Hemi)
Bore: 4.090" (+0.035)
Pistons: 9.5:1 Compression (Factory Hellcat)
Rods: 6.20" (Factory Hellcat)
Camshaft: Factory 6.1L
Timing Set: Factory 6.1L / 5.7L
Lifters: Factory hydraulic roller
Cylinder Heads: Factory 6.1L
Head Gasket: Cometic 0.027" compressed
Rocker Arms: Factory Gen III
Pushrods: Factory 6.1L / 5.7L
Engine 3 - 426ci Build - This is the final engine I plan on for my Charger... will be the 8th engine total so I am finally going "all out" so I never have to do another swap - I ended up using a 6.1L block instead of the BGE block because of the more simplistic lack of a VVT system - the downside of this is the lack of camshaft availability and the obvious VVT - However, I had scored the block for $100 so significantly cheaper than a BGE block (and the VVT style camshaft timing components) which has kept the cost of this build down significantly when combined with some shopping around. When this engine goes in it will be joined with a built Tremec T56.
Stroke: 4.080" Manley 4340 (192000)
Bore: 4.080" (+0.025")
Pistons: CP Racing 10.75:1 Compression
Rods: 6.125" Molnar DH6125NLB-T8-A
Main Bolts: ARP Main Studs
Camshaft: Comp HRT Stage II (112-337-11)
Lifters: Factory Hydraulic Roller
Cylinder Heads: Factory 6.2L Hellcat 53010753AB (Drilled for 5.7/6.1/6.4 Intake pattern)
Head Bolts: APR Head Studs
Head Gasket: Cometic 0.080" compressed
Pushrods: 11/32"
Oil Pan: Hellcat Hemi swap Pan (Holley)
Timing Cover: Factory Hellcat 68165888AE
Water Pump: Factory Hellcat 68268052AA
Oil Pump: Factory Hellcat 68195993AD
Induction: Factory Hellcat Supercharger 68373302AH
6.1 block stroked to 426 Molnar crank and rods Mahle pistons
Eagle heads ported
10.9.1 compression
Cam is 239/251 583/583. 112+2 centerline
Prefix intake and a 950 carb
Msd ignition
Assault water pump
ATI balancer
My build:
426ci build for boost, single 88mm turbo. This will be a street/strip 66' Satellite.
6.4 BGE block, ARP head and main studs.
Manley 4.050 4340 crank
Molnar PWR ADR 6.125 billet rods (2.00 rod journal, .927 pin, ARP2000 bolts)
Mahle 2618 forged pistons with gas ports (1mm, 1mm, 2mm ring pack)
ATI 918453 balancer
6.4 BGE heads CNC'd by Livernois (390cfm @ 600 lift with 2.14 valve)
Manley race flow valves
Cam will be custom grind from joe Greene racing.
