Roscoethug
Hoping for some advice and solution. The glove box door keeps popping open while driving, I'm guessing due to vibration. The lock and striker seem OK. Anybody else have this problem?
Had same issues with my 68 Charger. Tried adjusting different ways. Did not work, finally broke down and bought new latch. Seem to have fixed the problem. I replaced the one on the frame.Hoping for some advice and solution. The glove box door keeps popping open while driving, I'm guessing due to vibration. The lock and striker seem OK. Anybody else have this problem?
Did you swear at it?
That rarely works, but still it’s always the first thing I try.
Maybe a good blast of “Crud Cutter” to clean it out first. Give it a couple minutes to dry, then some light oil or graphite.Give it a shot of gun oil and see if your problems go away...
Slam the crap out of it....problem solved![]()
Thanks everybody for the fast responses. Colorado Dave - explain what you bent down from the upper tab... On the glove box door, there is lock with a toe that retracts when you push the button. Is that what you bent?
I've shimmed and adjusted the lower piece, and if that doesn't work I'll remove the sims from the lower and shim the upper piece. It closes tight, hinges are good, the and the glove box door doesn't jiggle at all. If this eastern PA weather ever breaks, I'll take it out for a ride and see if it worked.My 63 has a spring steel 'tab' that's screwed to the top of the glove box opening. It is adjustable fore and aft by loosening the 2 mounting screws. In my case, I had to bend the tab down about a 1/16" to give the 'foot' of the latch assembly a little more surface area to engage.
In looking at the 68-70 piece it shows a spring loaded latch bar at the top of the opening. Could it be that the spring is not applying enough force to hold the latch in engagement? If you've shimmed it down with washers and haven't solved the problem, the glove box door hinges are still tight, and the rubber bumpers are in place, I think I'd look at replacing the upper tab assembly.
https://www.classicindustries.com/product/all-years/plymouth/all-models/parts/mp14051.html
