Wow...who knew...it's toxic so don't use it, factory didn't use so why should i use it, don't need it in most engines because so n so said
This thread is perfect example of why some cars like mine are always faster than the rest. Certified glyptol user: intake valley, bottom of the intake on a sb, timing chain area, cyl heads
BTW, I have read nowhere in these two threads that anybody claimed it was toxic nor that there is a single case shared the coating has separated. The reason toxicity
question was asked is because history is filled with cases of things commonly used and blindly accepted for decades that later were shunned because of toxicity, like lead toothpaste tubes, the red leaded toxic paint used on Golden gate Bridge for decades, etc. I believe the coating has been in wide use way before lead was started to be removed from most coatings. Not sure how useful any lead is in an electrical insulating coating, but no one yet has shared a specific answer to the question. Knowledge is power.
"Alkyd resin
Alkyd painting
MFA# 1971.739
Description
A thermoset polymer made by the esterification of a polybasic acid with a polyhydric alcohol (
Glycol,
Glycerol, etc.). Alkyds were first synthesized in 1901 by J.Smith and later patented by General Electric in 1914. The first commerciallized alkyd paint was
Glyptal made by GE in 1926. As paints, alkyds are commonly combined with oils (
safflower,
soybean,
linseed, etc.) to form durable, resistant, nonyellowing paints. Oil-modified alkyds made with small amounts of added oil (30-45%) are called short-oil alkyds and are commonly used in baked enamel finishes on metal appliances and automobiles. Alkyds modified with greater amounts of oil (56-70%), called long-oil alkyds, have been used as house paints, artist paints (Griffin), and varnishes. They have good color retention and drying speeds that are faster than oil paints. In addition, alkyd coatings and paints produce a glossy, hard, tough, and durable finish. They do, however, have a tendency to drip and wrinkle in thick areas. The first molded alkyd resins were produced in 1948. The thermosetting resin has been used to make make car parts, electric switches, engine insulators, electronic components, and television parts." Wiki
