Jackpot50
Thought I would give this conversion a try because I will be convertion to a fuel injection setup later. I took my 440 to the Dyno to start and adjust everything before I got it into the car. Bought a mopar electronic distributer, GM electronic 4 pin module, blaster ss coil, made a mounting plate, wired & mounted it. Tried to start motor no spark, swapped wires coming out of distributer. Got spark but very hard to start. Has 12 volts to coil all wires are tight, after it starts runs great 469 Hp @ 6000 -528 fpt at 3500 but starts like crap timing set at 26 degrees advanced to get it started.
Put on a new module same results started hard ran good, next took off module and put on A MSD 6AL box started right up did run had to retard timing back to 12 degrees advanced did another pull 5800rpm 465 hp @ 5500 -528 fpt at 3500.
What is up with the module it is a 79 GM
This is got me scratchin my head.
