- 3:44 PM
- Apr 13, 2012
- Granite Bay CA
SOME people thought that I am the OP.
I am not. I chimed in to provide help. ONE member didn't, instead he decided to just chatter.
Look at post # 4, then 5.
SOME people think that they can dictate how the OP or others treat their cars.
These cars often sit awhile between uses. Sometimes stuff happens and we have to fix it to be able to drive the car.
For example...
This afternoon I went out back to start up my 72 Duster. I had ether and a battery jumper box. It was getting fuel so I assumed it wasn't starting due to the dreaded random no spark issue. You know, the only car I have here that never fails to start is the oldest and the only one with a points ignition?
My 2 '70 Chargers, the 75 Power Wagon and this 72 Duster have factory type electronic ignition and they all (except Jigsaw) have had the occasional no spark issue that often just goes away as fast as it comes along. Why is that?
The Duster had spark coming from the coil wire so the distributor was getting spark. It was dry inside. I removed the plug wire from #1 cylinder, put a loose plug in it and tested it for spark. Suddenly, it fired right up and ran on 7 cylinders. I shut it down and attached the plug wire and then it started normally.
Why? What did I change to induce it to start when it wouldn't before?
See? Weird stuff does happen and can be hard to diagnose and hard to prevent from happening in the future.
For example...
