good advice. I had an issue like this with an aftermarket battery negative ground cable that had pre-crimped connectors. The connector crimp failed in less than a year. All of those pre-made ones hanging on the rack at the parts store are crap. So I had custom cables made and haven't had a problem since.I have had intermittent problems with aftermarket ignition switches at the connector. I usually pull the connectors and squeeze the ends to make a tighter connection.
