gottagettamopar
I posted a thread recently to identify a gizmo attached to my dizzy and it turned out to be a GM HEI module. The advice received was to retain the module as it's considered an upgrade but I wasn't happy with the 4" chipboard screws attaching the coil to the inner fender, the offcut ally heatsink or the mounting of the module on the dizzy.
After a bit of trawling on the interweb I found a couple of neat solutions that I have adapted. I used a bit of scrap ally sheet from my local metal supplier, some careful measuring and a couple of hours cutting and filing.
I'm rewiring everything under the hood, so hopefully this will tie in nicely and I'm adding a relay.
Make a template and figure out where the coil, module, relay and heatsink will be positioned.
![IMG_0642[1].jpg IMG_0642[1].jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/135/135405-8c1b4bf5a0b889e8863e0d5751340f6b.jpg)
Shape up the ally sheet. I bent mine over blocks of wood held in a vice.
![IMG_0646[1].jpg IMG_0646[1].jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/135/135406-927ce2d46971a89d51360fc1d99a1d43.jpg)
Cut out a hole for the coil.
![IMG_0650[1].jpg IMG_0650[1].jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/135/135407-3c60de5b19df15d23bf5ac5b17d98ded.jpg)
Mount the module, relay and heatsink.
![IMG_0654[1].jpg IMG_0654[1].jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/135/135408-41f678eacdf4e885727f15640c5be7d2.jpg)
Mounted next to the radiator (sorry pic is sideways).
![IMG_0656[1].jpg IMG_0656[1].jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/135/135409-4a1ea3a3e71f888815729aab584e634f.jpg)
I found a heatsink on fleabay. It's a used Compaq pentium unit and the contact area is perfect for the module.
I think this is quite a neat packaging solution.
