JR_Charger
Just some resources for learning about grounding -
Relevant forum threads -
Ground Wire
Ground Straps
Ground Wire
Ground Straps
1) If you think about it, you'll come up with how the engine is grounded to the frame. 2 & 3) why, aluminum doesn't conduct electricity ?I've been thinking about all the ground straps on the Chevelle in the 1st video . . . On the 72 Charger, I haven't been able to find a ground from the engine to the firewall, or from the frame to the subframe. I do have the ground from battery negative to the core support, and to the engine cylinder head. Is it supposed to have the engine/firewall ground, and/or the frame/subframe ground? I'm thinking "no," but better to be sure.
What do you do when switching to aluminum cylinder heads? Move the ground to the block?
Where do you ground on an all-aluminum engine?
Are we talking about the frame or chassis? I don't even know if that is a concern on our cars - perhaps the Chevelle is a full frame car? Our subframes must be welded to the chassis so I'm guessing that grounds them together.
The rubber in the engine mounts and transmission mounts should insulate the engine from the subframe/chassis, so that can't be it. Maybe you mean that the engine grounds to the frame through the negative battery cable. I don't know of any other potential ground connections, but I'm no expert.
Regarding aluminum as a conductor, I know some metals are better conductors than others but I've never heard of aluminum being one of the good conductors. It sounds like you're implying that aluminum is adequate.
Start a new thread as you have a different issue. Year and model would be helpful.Any ideas I can't get my headlight to work as they were not very bright in the first place. I was under the dash changing instrument bulbs when it happened. I have power everywhere.
Almost all electric service lines to homes are aluminium.
It's cheaper than copperI was under the impression that aluminum was expensive - why use it instead of copper?
