Dibbons
- 2:30 PM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
My '72 SSP with power disc brakes stops just fine. The problem is that ever since I purchased it last December, the red brake warning light on dash is on all the time. If I unplug the electrical wire under the master cylinder on the valve that is integral with the steel brake lines, then the light goes off. Bleeding the brakes twice has not solved the problem, neither has overhauling the rear brakes. The front brake rotors are not scored, and the front brake pads have plenty of lining left. Other threads mention the same problem but end without a follow-up or definitive solution to the problem. Thank you for any additional information.
