Has anyone used PRW rockers ?
73dart360
12:01 AM
Fort lauderdale, floida
I need rockers for 440 source stealth heads , my machine shop said he thinks they are decent just wondering if anyone has any feed back i see a stainless alloy and an aluminum , i need the 1.5 ratio if i thought stock stamped would work id look for them it would save a bunch of money
I haven't used them, but have seen friends blow them up. If you cannot afford the Harland ones, get a set of ductile iron or similar. Just my opinion, but never skimp on engine parts.
BTW, the aluminum ones are the ones I've seen shred.
i don't know why the stock stamped wouldn't fit. i probably wouldn't use the stock or alum prw's on heavy springs and an aggressive high lift cam. the ductile iron won't break but do have fulcrum issues over time.
How much cam/spring are you running? We stuck on a set of MP's heavy duty stamped rockers on a small block with a .480 lift cam and turned it 6200. Only has about 30 passes but so far so good.
